XL Battery
  • 1 Reply
  • 1102 Views
pagenix
I purchased an XL battery for my Arlo Pro 4 so that I wouldn't have to charge it as often.  I bought a second one that I can charge and have ready when the current one needs to be charged.  However, it does not appear that I can charge the battery unless it's plugged into the camera.  I see that Arlo sells charging stations, but it is not clear if the XL battery is compatible.   Does anyone know if the charger will work with XL batteries and if not, what other options I might have?
This works (I use it myself with XL batteries):
  • 1 Reply
  • 1103 Views
