Pro 4 - Direct Wi-Fi Connection
  • 1 Reply
  • 2199 Views
J_K_T
If you connect directly to the wi-fi, without the hub, can you still access and manage the camera when you're not at home on your network? For example, use the ARLO app to manage the camera if you're not at home.
dcfox1
Yes but note without a subscription you won't have cloud recordings.
What options will I have when the Arlo Smart 3-month trial plan ends?
dcfox1
  • 1 Reply
  • 2200 Views
