  • 4 Replies
  • 2177 Views
Maverickgtr
Ever since the last firmware update at least one of my three cameras goes offline every day. I have to go out, pull the battery and then it’s fine. I’ve even removed one of the cameras from my account and reconfigured it but it’s still gone offline twice since I did that two days ago. This morning another camera went offline overnight. Firmware on all three is 1.080.16.2_16_7838050
Bring a camera closer to the hub or router to see if that helps.
Maverickgtr
One camera is about 2 feet from my wifi extender and it has also been affected. That particular camera is also wired for power. Spoke to support yesterday and changed my wifi channel to a different channel and now I’m monitoring for any offline cameras.
Maverickgtr
Changing the wifi channel has made the issue significantly worse and now one of my cameras will show as online, but you can't actually connect to it to play video and it won't give any motion alerts. Support has had no solutions other than removing and re-adding the camera from my account (again) and changing my wifi channel to another other channel.
varenummer
I have the same issues...
Did you find any solution ?
  • 4 Replies
  • 2178 Views
