Arlo Pro 4 Hard Reset Problem
@Jmillie wrote:
Please help! How do I reset a camera that won’t respond to the 15 second factory reset?
Try removing the battery for a bit, then reinsert it and do the reset again.
I cannot get my camera to do a factory reset. I’ve held the sync button down and everything. It just keeps blinking blue. The reason I’m trying to reset it is because it will not chime when I add to the app. Help!
How long have you held it down? Please also let us know what camera you have.
I also cannot get my brand new Arlo Pro 4 to reset. I synched it with my router, then tried adding a new VMB4540 base station. I removed the Pro 4 from the app and tried to synch it with the base station to no avail. They never synched. I tried resetting the camera several times. They still wouldn't synch. Now the camera will no longer reset. How long should I leave the battery out of the camera before I try again?
JattM,
Try plugging the camera in using a charging cable, allow it to charge for a short period of time and attempt another factory reset. After the reset is finished, attempt onboarding again. Do you still experience the same behavior?
Arlo Pro 4
labels
Samsung SmartThings
