Pro 4 Camera blue light goes out before being discovered
One of the Cameras dropped out for some reason and now it cant be discovered by the app hen I am trying to add it back, has anyone else had this?
Is the battery charged? What have you tried and what do you see? Have you removed the camera from Settings, My Devices and/or used the reset procedure?
Yes the battery is charged it has been charging all day, I removed the camera via my devices and get past the scan QR code which sounds OK but then app tells me no Cameras in range?
Are you connecting to your WiFi or to a base or hub? If WiFi, is it a mesh network or a regular router? Can you disable the 5GHz band for onboarding purposes?
Arlo Pro 4
labels
Samsung SmartThings
