I have a mode created that if there is motion detected on one camera, then it should record video on that camera plus record video on a second camera. Current rule is if motion detected on camera 1, then do the following: camera 1 record video and camera 2 record video. The rule has worked for several years but starting yesterday the second camera no longer triggers to record, only camera 1 is recording. I have tested by adding other devices with the "Add Device" but the additional recordings are not being triggered. I have another rule that says if motion is detected on camera 2, then camera 2 record and that rule woks fine. Is there a recent change that is affecting all rules being triggered?
While that's certainly possible, try rebooting your hub or base as well as reinserting the batteries in all cameras to get back to a known state.
Yes, re-started everything, but still not triggering recording on second camera (the additional rule in the mode). This all started happening after I upgraded my cameras form Arlo Pro to Arlo Pro 4. Currently have a case open with Arlo, sent them further details yesterday and waiting for update.
Arlo Pro 4
labels
Samsung SmartThings
