One Arlo Pro 4 camera is not recording while the others are
  • 5 Replies
  • 1377 Views
GSD
I'm using the 9.99/month recording feature successfully on 5 of my 6 cameras. The camera that isn't recording was working previously. It continues to issue notifications on my phone but I only get one still image.
5 REPLIES 5
dcfox1
Do you have the old smart plan with 5 cams max or have you upgraded the the newer secure plan with unlimited cams for same price? Also have you checked that the 6th cam is active in a plan in the subscription setting.
GSD
I have the newer unlimited plan. The errant camera was recording after I signed up but has since quit ÅND does not appear on my camera list for the record feature.
You might need to remove the camera, and then re-add it.
GSD
Removal crossed my mind BUT it is still providing alerts and still images so is communicating with my modem-WI-FI. I looked in vain for an "ADD" feature inside the record function.
Are you looking in the mode?  https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
  • 5 Replies
  • 1378 Views
