Not getting notifications any longer
Started a subscription with Arlo smart and quit getting notifications now? Was getting them before and I have not changed any settings. Apple 13 phone
First ( and easy ) thing I would do is to un-install and re-install the app.
See if that fixes things...
Also what iOS are you running? There were some minor issues some had with the 16+ version till upgraded.
Says running 16.1.1 so should be updated, I have also tried to reinstall it with no luck so far
Are you still experiencing this issue with receiving notifications?
Arlo Pro 4
labels
Samsung SmartThings
