  • 7 Replies
  • 4146 Views
liveontomorrow
Just purchased Arlo Pro 4 and found the battery low even after hours of charging. I can verify the LED comes on when charging and the camera is fully inserted into it's shell.
The camera does not require a hub/base station. It is connected to my 2.4Hz Wifi directly.
Also the app does not show a percentage on the camera of how exactly low it is.
Any suggestions?
7 REPLIES 7
The LED should only come on when power is connected and shouldn't remain on. Depending on the LED setting in the camera settings, a full charge would then illuminate the blue LED.
If the battery is fully discharged for any reason, read the FAQ in the support section that details how to get a full charge. Basically, it has to be plugged in multiple times to get sufficient charge in the battery to allow a proper charge.
liveontomorrow
Hello, thank you for your reply. This helps as far as the blue LED indications.  However, I don't think this solves the problem of the app showing the battery is at 5% or lower which puts the icon at red which means I will never know when to recharge the battery.
Is there an expected firmware or software update to resolve this?
You should get an email to notify <15% battery level (of course, if it's dropping rapidly that could be after the battery is dead). A good strategy is to occasionally check the level yourself - when the icon turn red it's below 25%. Recharge proactively - don't wait until it's a problem.
liveontomorrow
 It appears then that I have received a defective camera or battery and will need to return this device.
Thank you for your help w/this issue.
liveontomorrow
Scratch that last post. Before I decided to finally give up, I tried to "Remove Device", then reinstalled it (this would be my 3rd or 4th time total throughout this troubleshooting process). Magically, this last reinstall worked. I can see I have 100% of my battery working and the install even took me further with tutorials and offers than any previous time.
I guess I will be keeping this camera now. 🙂
JRock17
I also all of a sudden cannot get my one camera to charge. I have had them for 4 months and never had an issue. The charger is fine, as it charges my other 2 cameras no problem. Now it flashes blue for a few seconds like it always does when i first plug it in, shows its charging, but the percentage will not go up. I will try to uninstall and reinstall to see if that works.
liveontomorrow
Hi JRock17,  I would try the install and reinstall. Maybe even space it out a day in between installs (just something that worked for me).   In addition, if it still doesn't show a percentage, try using the camera for awhile. If it truly isn't charged, it won't last long with usage. You can also take a fully charged battery from your other camera and insert it into the problematic camera (just to be sure you truly have a fully charged battery).
However, the bigger issue is needing to get that percentage icon to show up and work. Otherwise, I don't think the app can acknowledge when the camera will truly have low power.  Good luck!
  • 7 Replies
  • 4147 Views
