Need to reboot Pro 4 after app update
  • 1156 Views
DrDon1996
have Arlo 4, when new update comes for app I need to reboot camera as it goes offline. Anyone else having this issue, app is on iPhone.
ShayneS
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
DrDon1996
I unplug battery, reboot and all is fine. Seems to happen right after app update. Easy fix, just aggravating.
Odd behavior, because the camera communicates to the cloud, not the app.
  • Is it possible that this is actually happening when the Pro 4 firmware is updated?
  • Have you tried logging in on a PC (browsing to my.arlo.com), and check the on-line status there as well as in the app?
  • 1157 Views
