My new PRO4 cameras will no record to my local storage, my existing cameras wil
Best answers
@eric22 wrote:
They are paired, I am not using the cloud only local, the cameras recorded local fine till the free subscription ran out.Your base doesn't support viewing the local recordings in the app - you have to remove the USB storage, and connect it to a PC to view the local recordings.
Have you done that (to confirm that the Pro 4 videos aren't saved there)?
Note your Pro 2 cameras have 7 days of free cloud storage, which the Pro 4 cameras don't have.
The Pro 4 cameras are paired with the base?
Are they recording to the cloud correctly?
Arlo Pro 4
labels
Samsung SmartThings
