Arlo Pro 4 Unable to set up
I have a 3-pack of Pro 4's, however only 2 were able to be set up. The third does not have fast blinking blue light.
Camera cannot scan QR code.. I tried using the sync button (holding for 15 seconds), doesn't work. I tried removing the battery for hours, and restarting the process, doesn't work. I tried charging battery to max power, doesn't work.
I do NOT have a hub or station. Any help is appreciated.
When i hold sync button, 3 amber lights NEVER show up. I can hold button as long as 5 minutes, or as little as 5 seconds.
It just stays slow blue light.
slow
blue
light
slow
blue
light
every
time
Sounds like you need to replace the camera. It's faster to exchange with the seller (if the return window is still open).
From looking online, a slow blue flashing light means connecting to a smarthub or base station, however i do not have any. This camera should be connecting directly to Wi-Fi.
nick123456789,
If you're unable to factory reset the camera using the steps in the following article, this could indicate an issue with the device: https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
If you would like to reach out to customer support to investigate further, you can do so using the Arlo mobile app: https://kb.arlo.com/000062610/Arlo-Support-Options
nick123456789,
I've opened and escalated a ticket including the details you've shared on the community. An agent will reach out to you with a status update as soon as possible.
Arlo Pro 4
labels
Samsung SmartThings
