Its stuck on 1.21.1.0_1431_9611cf3
Hi @sabbinanti
Firmware 1.24 is on a slow-rollout phase. Your other Smart Hub will receive the update. In the meantime, you can try rebooting the Hub if you have not already. to see if the update is triggered.
Arlo Pro 4
labels
Samsung SmartThings
