Motion detection notifications not working anymore
My recording stopped on May 7th 2024.
I have 3 and they all stopped recording. I have tried restarting my hub amd it doesn't make sense why they stopped. I tried replacing usb but I don't think that is the issue. I can try restarting and resyncing cameras but they are not easily accessible so makes it hard to do that.
Arlo, are you aware of this issue?
I know notifications work because I get request to allow new devices and I get notifications when I change alarm mode from motions to geofemcing and etc. I think there is a software or firmware bug.
Are you still seeing this same behavior?
My cameras have all stopped recording overnight as well.
They are all connected and I can see live video, but no motion detection recording.
I am not using a base station and have Arlo Pro 4 cameras.
Can you please check it now and see if it is the same behavior?
A couple cameras are now working but the rest are not.
Nope. All of them are not working again.
Under routines do you have the cameras set up under the different Arm Away, Arm Home and Standby with them to record?
Yes. Arm Away is active right now and that is set to record on all devices and alert me on all but one. I've tried toggling between a couple of them to see if that starts recording again and it has not helped. Now, one of my cameras seems to be working. 4 are not.
I’m not sure what’s going on. They all started working again.
Let me know if you see that behavior again within the. next few days.
The same happened with my 3 Arlo Pro 4 XL with SmartHub. All of a sudden, all 3 cameras have stopped recording or notifying me of motion starting on 5/23/2024. I made no changes. The cameras and Base Station are set to the standard 'Armed' setting with notifications enabled.
I reset my base station and removed the battery from one of the cameras to reset it. I have increased the motion sensitivity. I see the light blink which indicates it can detect motion when adjusting the setting, but it will not record any motion or alert me anymore.
There is no subscription on the account that is why you are no longer seeing those features.
What? I have a subscription and everything is working now.
@rkallman this was in regards to the other users question.
Hi,
I have not had a subscription since the free trial and have been using the system for close to 2 years now issue-free. I have been able to receive notifications and recordings are locally saved on a USB through my SmartHub. Did Arlo recently make changes in the past week?
I don't believe it was a subscription issue; I just received a motion notification so it seems like the issue has gone away.
My apologies, I misread what cameras you were using. Can you go through these steps too make sure that it is set up properly.
https://kb.arlo.com/000062816/How-do-I-enable-or-disable-local-storage-for-my-Arlo-SmartHub-or-Base-...
Arlo Pro 4
labels
Samsung SmartThings
