Unable to see "Library" and "Mode" tabs on Arlo Secure app. Do you need a Base Station to access these functions ? Config is four WiFi-connected Pro 4's with no Base Station.
I do see "Feed" instead of "Library"
Are you seeing "Feed" instead?
Arlo is slowly changing over their user interface from "Library" to "Feed".
Then you have the new "Feed" experience, and won't see Library or Mode.
Thanks. I'll mark this topic as solved. Just curious, where would I find this info on the Arlo product website ?
AFAIK, it's not on the main website. There are several knowledge base articles on the new experience, for instance
Arlo Pro 4
labels
Samsung SmartThings
