  • 8 Replies
  • 1161 Views
  • 5 In Conversation
jwebb10
Arlo pro4 cameras appear stuck in night vision. During daytime camera shows no colors. Have disabled night vision but still doesn’t show colors. Happening on 2 cameras
8 REPLIES 8
All of them or just one? Are they in areas that are heavily shaded? Have you tried reinserting one camera's battery to see what happens?
jwebb10
2 out of 7 cameras no longer show color. Have changed batteries , restarted and removed/added several times. Still no luck. Both cameras receive full sunlight. Seems only option is to replace cameras
Start by using the app to go to Settings, Support and select your camera. Scroll down to Contacts to see what official support may offer.
Edinburgh_lad1
Hero
Hero
Before you proceed with the support, which you can access if you have a subscription, ensure that your settings in the camera are enabled for colour. Additionally, ensure that there is enough daylight: sometimes cameras will switch over to nighttime mode if there isn't enough daylight. I can see that myself in my hallway, when on a dreich day, my camera activates a nighttime mode. Finally, disconnect cameras for 15 minutes as this can sometimes help, and if it doesn't, try resetting the cameras to their factory defaults.
jwebb10
How do I find if my cameras are set up for color in settings ? I know how to set up color night vision, but that doesn't help. I thought cameras were automatically set up for color. Have turned off and on, changed batteries, and rerstarted many times with no sucess. Thanks
Does the spotlight turn on when you walk in front of the camera at night?
jwebb10
yes. Night vision is set for color vision and spot light is on.
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
  • 8 Replies
  • 1162 Views
  • 5 In Conversation
