Hi,
I live in an area that has very poor internet service. Does the Arlo Pro 4 have the option to connect to the internet with a wire?
and
Can it download video to a hard drive?
Thank you,
PenGo
and
There are two ways to connect the Pro 4 - one is to connect it to your home WiFi, the second way it to connect it to a smarthub (using a closed wifi). Either way, the Pro 4 is using wifi - but the smarthub does connect to your router over ethernet.
The smarthub also supports local storage.
However, the system is built around a cloud service, so you will need internet. There is one option (the Arlo Go 2) that uses cellular - which of course requires you to pay for a data plan as well as the Arlo subscription. But it might be an option to consider if your internet isn't up to the task.
and
Hi,
Thank you for taking the time to respond promptly to my querie. My apologies for taking so long to respond (good thing I don't work in Support!). That was very helpful!
Arlo Pro 4
labels
Samsung SmartThings
