I have an Arlo pro 4 camera, but there is no way to hook up the panel to the camera. The camera does not have a USB port, why could it not have that when I ordered them together?
@Bfoulks74016 wrote:
So do you charge the camera?
The camera should have come with a charger and magnetic cable. If you don't have that, you can purchase one.
There is also a stand-alone charging station you can use:
What is the part number of the panel?
If should have been the VMA5600 - it has the magnetic connector that the Pro 4 uses.
Solar panel is VMA3600
That is for the first generation Essential cameras, so you somehow got the wrong panel.
Are you still able to exchange it with the seller?
No I am able to exchange the solar panel. So do you charge the camera?
Arlo Pro 4
labels
Samsung SmartThings
