I cannot log in to sign up monthly
  • 977 Views
Madman4ever
I’m really unimpressed with Arlo customer service.... the lack of phone number for support is infuriating on a $500 system...
I cannot even login to the website to join up monthly, so once my trial ends, I have no way to use the system. 🙄
Says something like “ocapi 0 unknown error”
the picture quality is pretty good but it doesn’t pick up license plates like I’d hoped either... it’s sad because I was going to buy another box but I’m just not comfortable spending the money knowing I get no support.
Dannybear
What user interface are you using, web portal or mobile app?
Regards the video quality, have you tried using a pc browser to view the recordings? The mobile app can only display low visual screen quality. It also helps if the object is static as motion is a problem. If you have a subscription they say you get better quality of motion but no one here has mentioned any marked improvement using subscription.
dmshaw10
Customer service is unsatisfactory; I have 3 Arlo wireless cameras and one does not go online from the initial purchase. I pay a monthly fee  and 2 of 3 works.  Also, purchased the long extension cables so I did not have to remove when needed to charge via USB. Camera still does not work.
Unhappy customer
Dannybear
@dmshaw10,
Have you tried contacting arlo support regarding your issue, use the app settings page to access your support options.
If you have 2/3 cameras working then it’s possible the 1/3 camera is faulty. They may also be able to help with the extension cable issues.
If you just want advice from other users here then start a new thread requesting help with further details.
  • 978 Views
