I called ARLO about by Arlo Pro 4 that stopped having power. It's been outside with normal rain
  • 1 Reply
  • 814 Views
dru1225
My Arlo Pro 4 won't turn on whether it's plugged in or using a fully charged battery; no lights etc.
It's been working outside for a little over 3 months. before I had this issue. When I took the camera from the case I did see some water in the case. I'm guessing this contributed to the issues.
When I called Arlo and explained the situation, they stated I needed to pay for a $99 or $150 to make sure firmware is updated automatically and that it is required to troubleshoot.
I questioned how this relates as it appears to be a hardware issue however they continued to press for me to purchase this plan.
Is this normal? Who should be helping me about a faulty camera that is no longer working?
Not normal - this sounds like you googled support and ended up with a scam support site.
The options for contacting support are here: https://kb.arlo.com/000062610/Arlo-Support-Options
  • 1 Reply
  • 815 Views
