How on earth do you actually speak to someone at Arlo uk?
Support number doesn't ring. Live chat doesn't connect... Chatbot more than useless.. Can somebody please let me know how I can switch a single camera subscription (pro 4) plan to another newer arlo (pro 4Xl) as its trial subscription is about to run out and I don't want to pay subscription for 3 cameras if possible. Many thanks in advance.
Kind regards, Joe
I believe the XL reference is the battery size so no difference plan wise.
If you have a multi camera subscription you should be able to use a pc web browser to login to my.arlo.com and go settings/subscription/manage and drag the device into the subscription.
When you tried ringing arlo was the number from the settings/support/your camera page phone number?
Arlo Pro 4
labels
Samsung SmartThings
