  • 1670 Views
Katmac2
Hi. I want to set-up a schedule without geo rules. Purely just if 8pm to 8am send notifications. Otherwise just record but no push notifications. I've read here about adding modes or schedules but cannot find those options in the app. Thanks
Browse to my.arlo.com on a PC, log in, and then select "mode" at the top.
Do you see "Add a Mode" at the botom of the screen?
For starters, read the following as you create a custom mode with the rules as you need.
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Once it's created and working as you wish, edit the schedule so that mode is active during your time period. You will need to split the schedule into 2 parts with the first from 12AM to 8AM and the second from 8PM to 11:59PM. You can't span days.
Katmac2
Thanks. Doing via the PC was very easy. All sorted now.
  • 1671 Views
