Hi team, I have Arlo Pro 4 cameras no Base station and everything was working fine. A week ago I started getting hundreds of AUDIO alerts. I have turned Audio alerts off and am still getting AUDIO alerts ... Does anyone know how to deal with this, please.
Do you have Smoke/CO alarms enabled in the smart notifications?
Is this happening on all cameras or just some?
Hi StephenB,
Thanks for replying, yes the Smoke/CO alarms are enabled.
Only giving false alerts on the 1 camera.
Thanks, Grant
Try disabling that, and see if the problem resolves for that camera. Smoke/CO is listening for the chirps from a smoke detector - there is no built-in sensor for them. If there isn't a detector nearby, it's best to turn it off.
Arlo Pro 4
labels
Samsung SmartThings
