Camera is not recognized by Wi-Fi chime goes off the camera is not recognized
Twiggy28,
Check to make sure your mobile device is connected to your 2.4ghz WiFi SSID. Also be sure you're entering your SSID and password for your network correctly.
If you're still experiencing an issue, try factory resetting the camera before attempting to onboard. Follow the steps here: https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Arlo Pro 4
labels
Samsung SmartThings
