Since the update to 3.5.10 running iOS 15.2 I have a green tint for a split second when the camera plays back movement captured at night. Oddly in the library it shows the video as being fine until you press on it and the video plays then this split second green tint happens. I have had my Carer pull the battery out and back in, the camera now works better but the odd green tint is still there, it does not occur though if you use live view and put the spotlight on at night or record in that way so it feels like a firmware issue again, maybe with the app or iOS, I've seen this before it comes and goes depending on the app or iOS version it feels like, whatever the cause its really annoying. Any answers to this issue would be greatly apreciated as the list of problems I've had with this camera just keeps on coming and its getting very tiresome.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Arlo Pro 4
labels
Samsung SmartThings
