Geofencing doesn’t work
Since the latest update of IOS 16.1.1 the geofencing function doesn’t work anymore. I don’t get the notification that the cameras are set to away mode and armed when I pass a certain geografical point (where they were armed before).
How do I fix this? Is there a upcoming new version of the Arlo app?
br
Emilio
Are you geofencing a single mobile device or multiple devices?
Two phones, both with ios 16.1.1 now.
Worked perfectly before the update.
If i look at the geofencing map I can see I’m out of the selected zone but the away-mode don’t trig anyway.
My granted user device stopped working with geofencing two days ago. Could be something similar. Re-adding user does not work.
There is a slow roll out happening now for app version 4.0. This should be available to most users by monday. Check to see if you're on the latest version of the app and test again to see if you experience the same behavior.
I'm having the same issue - geofencing no longer recognizes/senses my phone and I no longer get the location in/out notifications. Using geofencing with just one iPhone. I was working great before the upgrade to iOS 16, but now it doesn't. I've checked all the settings recommended on the Arlo website, and they all seem correct. I updated to the new Arlo 4.0 app yesterday. Hoped it would help, but it's still not working. Just to clarify, the app works and the camera is recording just fine, but geofencing doesn't recognize/sense the iPhone. Any chance it's because I also have a new phone?
... I should add that when the geofencing doesn't work, and the camera is still armed, I switch to Disarmed mode, wait a beat to be sure the displayed status is "disarmed", and switch back to the geofencing mode. Once I do that, the camera stays disarmed, but with the geofencing indicator next to it.
I also installed the latest version and geofencing does not work
I am using
Sounds like you need to have arlo reset your geofencing token in the base station/camera.
Arlo Pro 4
labels
Samsung SmartThings
