Generic USB solar panel works for Arlo pro 4?
I plan to get the aftermarket brand of solar panel. Those typically have the usb port not the arlo specific port. I am wondering if solar power would work if I connect the arlo usb charger from the camera to those solar panels?
Hard to say if a generic panel would work or not. Much better to get a third party panel designed for Arlo (Wasserstein sells one, not sure who else might). Either way, Arlo will recommend against it.
If you use a generic panel then
- You would need to get an outdoor rated cable - and Arlo doesn't sell them. The outdoor "cable" accessory actually has an integrated charger that can't be detached.
- The camera also needs to detect whether it is connected to an AC charger or a panel. It uses a lot more power when AC connected (due to features like foresight being turned on), so the battery will actually drain very quickly if it thinks it is connected to AC when in fact it is connected to a panel.
Arlo Pro 4
labels
Samsung SmartThings
