Firmware update failing
- 2
In trying to set up this camera, I can't get past the firmware update step. It took forever to get the camera to connect to the WiFi router, but now I get repeated messages "Checking for firmware update failed" and cannot get to the next stage. Two other cameras went through the process without this problem.
full battery and full strength.
Understood, but not enough for actvity zones. Either AC power (for camera-processed zones) or a subscription (for cloud-processed zones).
My issues started with 2 Arlo Pro 4 cameras (out of 6), failing to be recognized during the setup process, but then my replacement cameras wouldn't get through the firmware update. Of course I removed the devices from the Arlo app, and pressed the reset button on the cameras and waited for the 3 orange flashes to reset the cameras each time, but I did 2 others things I hadn't done before. First, I moved the cameras completely away from any other wifi or electronic devices, and about 5 feet in direct line of sight of my router. Then after my camera recognized the bar code and chimed (everyone seems to get through that process), I immediately plugged in the AC power cord to the camera and left it to finish the setup process. I had charged my cameras overnight thinking that was more than enough power for the setup process, but maybe getting rid of any possible interference, and giving the cameras the full power of the AC power cord was just enough to complete the setup. Fyi, I bought my cameras in packs of 3 on Amazon (so they sent me another 3 pack). It took 3 replacements to get 2 working cameras.
An update, for all with UniFi wifi related challenges, especially failing firmware update, discovery and disapointing camera battery life. A couple of weeks ago using UniFi network application console / app I have fixed all cameras to their respective ACs. What I have noticed is that cameras (I have 9) started to behave much better, not going into offline as they did from time to time, connection times improved, overall the setup immediately started to feel more robust. Now, today I got dreaded 'Update Firmware' notification for all 9 cameras... This time however, I was able to update the firmware, via browser (Google Chrome) and updating camera one by one. Interestingly, when I clicked on all cameras to update in parallel I again ended up with 'Update Firmware available...', but... When I tried to update one by one then it worked. So, it must have been connected with some UniFi dynamic AC allocation protocol confusing Arlo cameras, blocking discovery and in parallel draining batteries (yes, once I pinned cameras to their ACs I have also noticed much better battery life... Like, 3 times better...)... So, if you are with UniFi setup, still struggling with updating firmware, discovery, or disappointed with battery life you may try fixing the cameras to ACs via Unifi network app... Hope this helps
Had to get a warranty replacement. The replacement camera would not update firmware. I scrolled through this post and found a suggestion to use a mobile hotspot to update the firmware. I did it a little differently and used an alternate wi-fi, new account with Arlo, factory reset camera, camera was recognized, firmware updated. Then removed the device from the new Arlo account and added the camera using the "add new device" following the directions from my original Arlo account. Finally worked. I work with some awesome software engineers that could fix your issues with your system if Arlo company is interested, contact me. Thanks! I hope this helps others.
And.. No. With 1.080.18.6_66_bda8d63 update again having the same 'Firmware Update' available message, so fixing cameras to access points not helping this time. I am beyond 'losing' patience as with 9 cameras, dreading the day when mandatory 'firmware update' will pop up... so, having again to fiddle around removing cameras from the system, adding it to some pure internet mobile hotspot, adding them back again and... then re-assigning them on the network to keep the topology up to date... crazy, simply crazy
OK so despite the very unhelpful input from Arlo, it does come down to the 2.4Ghz issue. You need to access your Wi-Fi router from a web browser and look at the Wi-Fi channels settings. There should be a separate setting for each of 2.4 and 5ghz. Your router settings would normally synchronise both channels, you need to untick that box if one there. You then also need to rename your channel in the SSID section to something similar but perhaps just adding “-5g” at the end. Save your settings.
When you scan for Wi-Fi networks you will see your existing network which is now just 2.4ghz and another network with the -5g postfix which is just 5ghz. Connect to the 2.4ghz network and your updates etc should work just fine.
Go back into your Wi-Fi router and reset the settings as above and don’t forget to send flowers to the helpful folk at Arlo.
I am having big issues with this firmware upgrade.
Arlo said to call my ISP and disconnect 5 giga hertz bandwidth. Did that and then couldn't get online to anything!
Changed and upgraded mobile phone, where the Arlo app is and still the same
Arlo sent replacement camera. Now got 4 cameras and none of them work !
It is driving me crazy, as Ive spent 3 days trying to resolve this. Everything was working fine for months until this firmware upgrade was attted to be pushed through.
I do that and then I can't get online to anything !
Works laptop. IPAD. Everything !
Make sure that
- the router settings permit WPA2 (AES) connections
- there is no punctuation (including spaces) in the wifi network name and password
I purchased 4 Arlo Pro4 yesterday had no problems setting 3 out of 4 cameras up initially. The 4th would chime when passed over the QR Code and that was it. The APP couldn't locate it. I tried this several times as other people have done with no success. I then discovered 2 of the camera's that were installed the spot lights couldn't be turned off from the APP. I rebooted/reset the phone and all problems were solved. The 4th camera installed without any problems and I was able to turn the lights off on all 4 cameras. Installed using a Samsung Galaxy S22
Tried this.
And battery is 100%
And wifi signal is 100%
And tried over LTE
Still doesn;t work.
Piece of garbage,
I tried this and it didn't work. I don't know what to do now with 2 cameras down.
- 2
Arlo Pro 4
labels
Samsung SmartThings
