  • 2 Replies
  • 1205 Views
manager159
Does the Arlo Pro 4 XL require a hub? I know the pro 4 doesn't  not sure if the only difference is battery size. So is it the same camera with just a larger battery and they both operate the same?
Thank you
It is the same camera, just with a bigger battery and a bigger shell.  You can't use the magnetic mount - the larger camera is too heavy for it, and Arlo left out the steel in the back of the larger shell.
manager159
Thank you just wanted to make sure no hub required most pictures show the pro 4 xl with a hub. Good information thank's again.
Ernie
  • 2 Replies
  • 1206 Views
