Where to buy Pro XL bodies or sleeves/skins?
  • 8 Replies
  • 2783 Views
daddydg
I recently bought the Arlo Pro 4 XL bundle from Costco. The cameras bodies came in white, but I'd prefer it if they were black.
Does anyone know where I can buy replacement bodies or sleeves/skins for the Arlo Pro XLs?
8 REPLIES 8
Did you check https://www.arlo.com/en-us/accessories.pro3.pro4 as well as Amazon and Bestbuy?
jpmichaels
Arlo does not carry one for that model (I just confirmed via chat). Amazon carries plenty for the Pro 4, but the XL is a bigger camera. BestBuy is the same. If I find something that works, I'll post here.
daddydg
Thanks, JP! I appreciate the info and follow-up.
Hopefully, someone comes out with them soon.
You can also just remove the case and spray paint it. I've done that before.
jpmichaels
Hi - sorry for the delay in posting. Wasserstein makes silicon sleeves for Arlo and other cameras, and they told me they were working on one that would fit the Pro 4 XL. I'll let you know when they do.
Herk1995
Target sells Wasserstein covers for Arlo Pro 4 XL.  $29 for a pack of 3
daddydg
Thanks for finding the item at Target.  I also just found it on Amazon for $19.99
jpmichaels
Thanks, all! Just ordered!
  • 8 Replies
  • 2784 Views
