Connecting Pro 4 with 5Ghz bandwith router
  • 1 Reply
  • 1087 Views
TrikingMama
 Our new home has a 5Ghz router so I'm unable to connect our Pro 4 devices directly to wifi.  If I add a SmartHub or base station to the system will I be able to use the Pro 4's.  Support suggested I call my internet provider to change our internet to 2.4Ghz. Thanks!
Almost all 5 ghz routers are using both 2.4 ghz  and 5 ghz radios, so you should be fine.
If you want confirmation, please provide the manufacturer/model of the router.
The 5 Ghz is just the wifi, not the internet.  In any case, it's almost certainly not needed.
  • 1 Reply
  • 1088 Views
