Compatible Solar Panel for Arlo Pro 4 Spotlight from Bestbuy
  • 2 Replies
  • 1340 Views
SueL
I recently purchased the three pack of Arlo Pro 4 Spotlight cameras from Bestbuy.  I want to add a solar panel but this particular model VMC4350P is not listed in the compatibility list.  Has anyone purchased a solar panel that is compatible with this particular model?
There is no such model. The two Pro 4 part numbers are VMC4050P and VMC4041P.  You must have puchased the VMC4350 system bundle.  That has 3 VMC4050P cameras.  The 3 in the bundle is the number of cameras included.
This is the panel you need:
FWIW, IMO Arlo part numbers and system skus are really messed up.  They make figuring out what you have far too difficult.
SueL
Thanks!  That makes sense.  😀
  • 2 Replies
  • 1341 Views
