Compatible Solar Panel for Arlo Pro 4 Spotlight from Bestbuy
I recently purchased the three pack of Arlo Pro 4 Spotlight cameras from Bestbuy. I want to add a solar panel but this particular model VMC4350P is not listed in the compatibility list. Has anyone purchased a solar panel that is compatible with this particular model?
There is no such model. The two Pro 4 part numbers are VMC4050P and VMC4041P. You must have puchased the VMC4350 system bundle. That has 3 VMC4050P cameras. The 3 in the bundle is the number of cameras included.
This is the panel you need:
FWIW, IMO Arlo part numbers and system skus are really messed up. They make figuring out what you have far too difficult.
Thanks! That makes sense. 😀
Arlo Pro 4
labels
Samsung SmartThings
