Clip snapped
Anyone know how to get a new clip for the magnetic wall mount as it snapped. Thanks
You can try using the app to go to Settings, Support and choose your camera. Scroll down to Contacts to see if official support can send you one. If not, there's a ton of threaded camera mounts from Arlo and Amazon that can be used for cheap.
Arlo Pro 4
labels
Samsung SmartThings
