Changing battery in Arlo Pro 4
  • 1 Reply
  • 2401 Views
Boomer12
I have 3 Arlo Pro 4s. I know it is designed to be "safer" because you have to insert a little key instead of pushing a button to remove the camera from the housing. On the older models, with a "button," the camera pops out. With the Arlo Pro 4, when you "release" the camera, it does NOT come out. Anyone have any ideas of how to make it come out
This is a function of the o-ring around the camera for weather-sealing. I find that holding the camera face down and shaking it into my other hand causes the camera to be able to be removed from the case (do this carefully!). A light wipe of grease on the o-ring may be useful to prevent this.
  • 1 Reply
  • 2402 Views
