Trying to subscribe to CVR plan for Arlo pro 4 wireless. I click on subscribe now button it says choose your cameras but there is nothing to pick from it is blank that continue button is grayed out anybody else having this problem.
5 REPLIES 5
It may be that none of your cameras is connected to AC power. I don't know for sure that this would be the cause but CVR requires AC power since the battery would go flat quickly.
Thank you for that information. I currently have my cameras hooked up to solar panel. I did unplug solar panel and plug it directly into AC. But I still have the same problem where the cameras do not show up where I can pick them for the CVR plan. Still trying to figure it out thanks again.
I don't know how dynamic the choice of cameras for CVR is so try canceling your subscription and resubscribe with the cameras already on AC power. No guarantees...
Did you connect to wifi router directly or to a smarthub/base station? It seems CVR works for smarthubs/base stations only.
Arlo Pro 4
labels
Samsung SmartThings
