VMB4500 usb storage fails to initialize
  • 2806 Views
ogxm
The specs on the type of flash storage are generic enough. I have tried a typical USB flash and a mini SD card on a USB adapter and both failed to initialize.
What type of device is expected on this model?
My VMB5000 worked as advertised as soon as I type connected the mini SD card.
dcfox1
Have you tried  formatting the USB drive in the settings, it needs to be 16GB or greater.  I doubt a SD card adapter would work. I use a 32GB Thumb Drive. Just to make sure you are not trying to view the 4500 recordings in the App since they won't be there.
How do I set up local storage backups on a USB device using my Arlo base station?
dcfox1
ogxm
dcfox1, I'm beginning to suspect the adapter as well, even though the HUB sees that it has a device on its USB port. It just fails to work well with it.
I did make sure it is FAT32 and is only 256GB in size, so well within the 2TB limit.
Also, I did try a USB thumb drive in my very first attempt and it too failed to work with it.
The app or web front-end produces NO logs/info/errors that I can use to guide my understanding of where the issue is.
Their integration is not as robust as one could wish for.
ogxm
Indeed.  Swapped for a regular, boring USB flash thumbdrive and the hub loved it. Go figure.
Seems like the Hub's software is qualifying its valid device to match exactly a thumb drive, not any storage device with FAT32 for file system.
Thanks to all who replied.
  • 2807 Views
