@LF760 wrote:
How do you cancel a camera trial period and add to an open account
You can't cancel the trial - I'm not sure why you'd want to.
Are you wanting to move the camera to another account and restart the trial? AFAIK that is not possible.
Then how do you adjust the record time on a camera on the trial period
Do you mean the length of each recording? Or something else?
If you see "Library" at the bottom of the app, then you adjust the recording length this way:
If instead you see "Feed" and "Dashboard", you do it this way:
Arlo Pro 4
labels
Samsung SmartThings
