Can't sync Arlo 4 after amber and blue lights ok
  • 4 Replies
  • 1627 Views
Doug-Padgett
This is my 4th camera. First 3 went fine. Tried procedure 6 times. All attempts fail in the final discovery sequence. Replaced battery; deleted and started over; changed netwoks; made sure my Samsung phone was on same networks. Horrible customer service not being able to call support. Lots of money for this. Where's your phone number?
Doug-Padgett,
Try connecting the charging cable and then go through the onboarding process again. Do you still experience the same behavior?
Try the reset procedure found in the FAQs in the support section here. Hold the button for >10 seconds until the LED flashes amber and try again.
Doug-Padgett
I deleted it from my app; I performed the factory re-set; I got the amber light; I got the blue blinking light; all this about 6 times. Sorry-that's what I meant by my short-hand in my first message. My other three cameras are working fine. How do I send this back. It is intolerable that Arlo does not have a phone for customer service and forces the community to answer. There is not even a way I can see to return a bad product.  Please help!
Doug-Padgett,
Doug-Padgett
Thanks. I did that two previous time-no luck. Then waited a day and it has finally worked.  I'm connected! I still have a real problem with no "factory support".
  • 4 Replies
  • 1628 Views
