After watching a lot of videos and reading trouble shooting posts they will not connect to 2.4 network. Printed out Pro 4 manual as well
I called provider and they set up a separate name and password for the 2.4 internet and still can't connect.
Get QR scanned and then just watch over and over searching for camera.
Try using a computer browser set to my.arlo.com. Does your SSID and/or password for the WiFi have any special characters or spaces in them? You may also want to try the camera reset procedure:
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Arlo Pro 4
labels
Samsung SmartThings
