Hi
I am trying to integrate my Pro 4 cameras into my Raymarine video feed. Raymarine say the following about 3rd party cameras.
Third-party cameras are not tested by Raymarine, are not explicitly intended to be supported, and we cannot offer any support if you choose to use a third-party video device, but they may well work provided that they fulfil at least the following minimum requirements: Must support H.264 video compression Must support RTSP (Real Time Streaming Protocol) Must support ONVIF Service Detection (ONVIF User Authentication MUST BE DISABLED) ... inability to configure this IP camera feature is the most common cause for IP camera incompatibility. Must have DHCP enabled & Dynamic IP set to ON 720p or 1080P resolution |
Can anyone tell me if Arlo cameras (specifically the Pro 4) are compatible with these requirements?
If not, is it possible to live stream to a tablet?
Many thanks
D
None of the Arlo cameras (including the Pro 4) meet these requirements. They are not ONVIF cameras.
You can install the Arlo app in Android or iOS tablets, and livestream from the app.
Logging into the app on the tablet will result in logging you out on the phone. If that's a problem, you can also set up a friend account to use on the tablet.
Thank you Stephen
Very useful.
D
Arlo Pro 4
labels
Samsung SmartThings
