  • 8787 Views
AFreeze
I have an Arlo Pro 4 camera inside plugged into an Arlo charging cable. From what I gather the blue led light blinks anytime it is recording. This light is a nuisance. Can it be turned off? My other cameras that I have don’t do this. It is a fast blink that happens all the time it seems like. Yes I have turned off the LED for full battery toggle.
While it may be a faulty camera, try triggering motion using battery-only, AC-only and both battery and AC. It may be worthwhile to remove and re-onboard the camera.
AFreeze,
A fast blinking blue LED means the camera has synced to a base station/SmartHub/router. There is no LED behavior associated with motion detection. See here: What do the different LED behaviors on my Arlo camera mean?
AFreeze
So then why is my camera always have a blue blinking light?  I do not have a hub so you are telling me it is syncing to my router all the time.  None of my other cameras do this.  It should not be having trouble syncing.  Is there anything you can suggest as to why this camera constantly is blinking blue?
  • 8788 Views
