Battery will not charge
One of my Pro4 camera batteries doesnt seem to be taking charge
If you let the battery fully discharge you can try the following FAQ. The key is to plug in and unplug multiple times to get enough charge into the battery to then allow it to charge properly. If this is the case, proactively charging the batteries is a Good Thing.
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Arlo Pro 4
labels
Samsung SmartThings
