  • 2077 Views
BryceRusson
Why is my Arlo 4 camera battery draining so fast in a day or more?
Generally fast battery drain is due to
  • a poor wifi connection (drops require the camera to actively restore the connection, which can use a lot of power)
  • a lot of video streaming activity
Are you seeing any signs of a poor connection?  Inability to livestream, or corruption in the recorded video?
Also, about how many minutes of video is being streamed per day?  To estimate this you need to delete any activity zones, and monitor for a couple of days - as they mask activity.
eelpout
Mine just started doing this as well. Pro 4, tried with 3 different Arlo branded batteries. All drain to zero in about 30 hours.
No movement is detected. I've reset it twice.
Did you ever find an answer?
ShayneS
@eelpout
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
  • 2078 Views
