My Arlo Pro 4 battery is at 26% and should I totally drain battery before charging it back up?
No. If you let it totally drain, it can be difficult to get it to charge again.
The app should show you an amber color on the battery if the charge drops below 20%. That's a good time to charge it.
Arlo Pro 4
labels
Samsung SmartThings
