How to record in 1080P and NOT enable Autozoom & Tracking on Pro 4?
  • 1 Reply
  • 735 Views
Henri8
I want to be able to use my browser to view recordings, which means record in 1080P and not 2K.  I also DO NOT want to enable Autozoom & Tracking in Pro 4, which is choppy & jumpy.
How do accomplish this?   (Should be simple!)
@Henri8 wrote:
I want to be able to ...  record in 1080P and not 2K.  I also DO NOT want to enable Autozoom & Tracking in Pro 4, which is choppy & jumpy.
AFAIK there is no way to do that.  I wish there was a way to set the resolution (as there is in the doorbells).
FWIW, this is possible for 2K/4K if you have a newer PC (6th generation Intel or AMD or later) and are ok using Edge to log in.  You also need to purchase the Microsoft HEVC extension for Windows from the Microsoft store ($0.99 last I looked).
  • 1 Reply
  • 736 Views
