I have 2 Arlo Pro 4 cameras. I don't intend purchasing a plan but want to save footage locally. Which base station is compatible with the pro 4 and what are the pros and cons of using a base station?
billsspace,
Take a look here for a comparison of each base station/SmartHub: Arlo SmartHub and Base Station Compatibility
Thanks James. I'm going to look for the VBM5000 Smart Hub. So far it is not available anywhere?
Arlo Pro 4
labels
Samsung SmartThings
