Arlo Pro 4 stops recording at night
  • 4 Replies
  • 1485 Views
Duffinator
Just set it up yesterday afternoon. Stopped recording at 9:30pm and came back on at around 6am.  There are a number of posts stating the same issue.  I have no filters on, etc.
WHat mode are you using, the default Armed mode or a custom one? Are you using a schedule? Be sure to check everything. Run tests yourself - perhaps just nothing happened that triggers a recording. Walk back and forth at different distances from the camera to see how far from the camera you can be to get a recording.
Duffinator
Armed mode, no schedule.  No recordings since 9:30 pm last night, and lots of activity outside.
Have you tried the testing I suggested?
Duffinator
Returned camera after about 3 weeks of use. Worked very well for about 24 hours and that was it. Then stopped picking up moving objects unless right in front of door entry. Finally it disconnected from wifi and would not reconnect. Wifi hub is very close to front door, not coverage issues.
  • 4 Replies
  • 1486 Views
