Base station and Pro 4
  • 1 Reply
  • 769 Views
Mudra
I am receiving conflicting information on which base station is compatible with Pro 4. I need additional storage. How do you connect base station to Pro 4 once you have one? Thank you.
https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
If you want to see this in the app, then you need a smarthub - either a VMB4540 or a VMB5000.
Either way, you will need to remove the storage from the base and connect it to a PC in order to go back more than 30 days.
Remove the camera from your account, and then on-board it again (telling the system to connect via the base).
You might as well do a reset while you are at it.
  • 1 Reply
  • 770 Views
