Hi thre
First time buying a security camera.
I GOT MY arlo 4 pro (4pacakge) . I wonder whether or not it is worth getting the Samart hub?
Can someone share/ let me know if it is worth it?
1. What is it the differences between the smart Hub or paying the app services?
2. I'm bit confused about the differences/advantages of those 2 (app fees / smart hub)
There is no difference between using the hub or your WiFi. The subscription is required for any camera newer than the Pro 2 since 2018 for cloud recordings. The hub can be used for local recordings but it's not the same as having the sub and cloud recordings.
https://kb.arlo.com/000062312/What-options-will-I-have-when-the-Arlo-trial-ends
Arlo Pro 4
labels
Samsung SmartThings
